cannot connect my router by console
Answered Question
May 11th, 2008
I have 3825 router and I want to configure it. This router configured once but I forgot my password and IP address of that router.
When I plug the console cable and use the following setting on SecureCRT.
Baud rate 9600
Data bits 8
Parity None
Stop bits 1
But some strange characters displayed on the screen.
Does anyone know what is the problem it is ? How to solve it ?
Thank you.
Best regards,
Correct Answer by gpulos about 8 years 5 months ago
Try the following for starters:
1) Disable any flow control and attempt again.
2) Turn RTR off, wait a few seconds, and turn back on.
3) Verify console cable and connection. (try another console cable if possible)
For password recovery use the following link:
Overall Rating: 4 (1 ratings)
tseveendorj Mon, 05/12/2008 - 18:41
Thank you for your reply.
solved the problem. That was baud rate. I changed from 9600 to 38400 then I got the link.
