CRS recording tool - CRSraw2wav
May 11th, 2008
Hi all,
I have a question about the CRSRaw2wav.exe tool: If I use this tool to convert the file from raw to wav format (using cmd line CRSRaw2wav.exe <filename>), when playing the wav file, I can only hear the voice of the agent (couldnot hear the voice of the caller). Could someone explain this for me and give me some solution?
hoanghiep
htarra Fri, 05/16/2008 - 10:50
Go to your recording server
C:\Program Files\Cisco\Desktop\Bin\raw2wav.exe
You have to supply the to.raw or from.raw file name and it will combine them to .wav file.
You just need a batch file to convert the file
FOR %%A IN (*.from.raw) DO ("c:\Program Files\Cisco\Desktop\bin\raw2wav.exe" %%A)
Schedule it and voila third party tool.
And also Just one more information for you.
I found that file as CRSraw2wav.exe and STLallocator.dll is required for this software.
CRSRaw2Wav
Usage: CRSRaw2Wav.exe filename
OPERATION:
-- takes a RAW file name as a parameter (filename)
-- finds the matching pair (if "test.from.raw" is passed the matching pair will be "test.to.raw")
-- converts/merges the two into a WAV format file with the same base name ("test .from/to.raw" will go into "test.wav")
-- if a WAV file with same name as the one that is about to be generated already exists in the destination directory then the conversion is not executed
ASSUMPTIONS:
-- the source directory is the current repository for recordings; if not found in the registry this location is assumed to be "c:\program files\cisco\desktop_audio";
-- the destination directory will be "..\desktop_wav" from the source directory);
