05-11-2008 08:30 PM - edited 03-05-2019 10:53 PM
Explain me about collision domain in LAN.
Thanks in advance
Cheers
Bava
05-11-2008 09:29 PM
collision domain means when a frame sent by one system is having possibility of colliding with the farme sent from another domain.usually this happens when u r using a hub.
Mahmood
05-12-2008 01:23 AM
actually when a frame sent by a system having a possibility of colliding with frame sent by another system or domain..in switch every port is a collison domain.what does it mean.is every port having a chance of colliding with another pc frame
Cheers
Ahmed Bava
05-12-2008 02:04 AM
For the switch each port is a separate collision domain.In switches there is no possibility of frames colliding with each other becoz each port on the switch represents a seprate collision domain.
Mahmood
05-12-2008 05:25 AM
Lets say the pc connected to a switchport is sending frame & at the sametime a frame came to this pc on the same port. In this case, the 2 frames collide, but it doesnt impact any other pc's connected to the switch. thus each port is called a collision domain. You can overcome this with full-duplex configuration on switchport. With full-duplex, each port can send & recv simultaneously.
