RSTP
May 11th, 2008
What is the convergence time for RSTP and how does it converge.Let me know how to configure PVST in the segmented LAN switching environment
Cheers
Bava
Overall Rating: 4 (1 ratings)
cisco_lad2004 Sun, 05/11/2008 - 23:15
Bava
I strongly recommend you read up the below links.
convergence for RSTP is in the order of seconds. (I had 16 switches in a ring, and converged in less then 3s).
http://www.cisco.com/en/US/docs/switches/blades/3030/software/release/12.2_37_se/configuration_/guide/swmstp.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml
if you are forecasting to have many VLANs, then go for MSTP which will enable RSTP. but i you will only have fewer, then you may choose to configure R-PVST.
Pls rate all helpful posts.
Sam
