URN_NOT_FOUND error is shown when try to exec config import
Answered Question
May 11th, 2008
My server was restarted and after the machine has come back I made all the services related to CW but while executing cwcli config or get command ,Am
getting following error
<!-- Executing: cwcli config import -u admin -p admin -ipaddress 172.16.100.19 -f C:\CiscowkIns\cwConfigFile.cfg -->
<cwcli> INFO - Devices to be attempted in the job:
172.16.100.19
<cwcli> ERROR - URN_NOT_FOUND : urn "JRM" : Not found !!
<cwcli> ERROR - The job could not be created.
Correct Answer by Joe Clarke about 8 years 9 months ago
You have a process failure, or you have not waited long enough for everything to startup. It appears the jrm daemon is down.
I'm not sure what you mean when you refer to services. If you have manually started CiscoWorks Windows services from the Services Control Panel, this is wrong. The Daemon Manager is the only thing that should be starting these services. If they do not get started by dmgtd, then that points to a problem with your server. The output of pdshow would be helpful.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 05/11/2008 - 22:22
er_yogendrasingh Sun, 05/11/2008 - 22:36
Thnx joi for reply.
attached is the pdshow output.
and by starting services manually I meant that by starting the daemon and other services from AdminTool-->service in windows as they did not come up automatically(as they are set to manual)
// please let me know if any other log u may want// thx
