SMTP settings failed to apply... ???
Answered Question
May 11th, 2008
I just installed LMS 3.0 and December 2007 update and still the problem exist. it doesnt allow us to configure SMTP Settings. I have found out that there are 2 bug id related to this... CSCsm10925 and CSCsg02991. Both have fixed status but it confuses me... How can we fixed this problem? Please help.. thanks..
regars,
Correct Answer by Joe Clarke about 9 years 1 week ago
There is no other way to get this patch. However, you can run the following commands to manually set the SMTP server:
NMSROOT/MDC/bin/ccraccess -removeResource Core Custom Custom "" ""
SMTPServerName
NMSROOT/MDC/bin/ccraccess -addResource Core Custom Custom NEW_SMTP_SERVER ""
SMTPServerName Owner System DefaultData localhost Description SMTPServer
Where NEW_SMTP_SERVER is the desired value for the SMTP server hostname/IP address.
Overall Rating: 5 (1 ratings)
miheg Mon, 05/12/2008 - 03:08
  • Gold, 750 points or more
Apart from an SMTP server name or ip address and an emailID to use there is nothing you can configure.
Do you enter this name or address at CS -> Admin -> System preferences?
What error/message do you get?
Cheers,
Michel
miheg Mon, 05/12/2008 - 03:27
Actually, the SMTP config lives in the directory CSCOpc/MDC/etc/regdaemon.xml.
You may want to put it in there directly or check if the file isn't corrupt.
Cheers,
Michel
Joe Clarke Mon, 05/12/2008 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You're hitting CSCsm10925. I have a patch available which you can get by calling the TAC and referencing this bug. I would caution against editing regdaemon.xml directly as any typo here can prevent anything within LMS from working.
jnerecina Mon, 05/12/2008 - 17:00
Hi jclarke,
thanks for the reply.
Do i really need to open a new TAC case for this? Would there be other ways to do that. Because we only have a limited number TAC case to raise, we are Cisco Partner, and we can't just open a TAC case. It needs to be approved first... is there any other way to get this done? Thanks...
Correct Answer
Joe Clarke Mon, 05/12/2008 - 19:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
SMTPServerName
