Store and Forward Super Group 3 Faxes
May 12th, 2008
Does store and forward support Super Group 3 Faxes? Group 3 faxes from PSTN/Fax to mail box arrive with tiff file without any issues. With SG3 faxes I just get the first inch of the image within the tiff file in the email.
I've tried changing the imaging encoding under the mmoip dial peer to the different options but with the same issue.
Michael
Anonymous (not verified) Fri, 05/16/2008 - 10:54
Yes store and forward support Super Group 3 Faxes. The off-ramp router converts the attached TIFF file back into standard fax format and then transmits the information to a standard Group 3 fax device. Off-ramp faxing activities are not mutually exclusive.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t4/feature/guide/allegro.html
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a0080114565.shtml
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/t37.html
