05-12-2008 01:22 AM - edited 03-15-2019 10:35 AM
I have a callmanager 4.1.3(sr2) with phones 7912, 7940 and 7960. I bough phones 7911 and I had to install a device package because the model 7911 did not appear in the list when I wanted to add it. The phones 7912 had the corporate logo and after install the device package it has disappear and now the phones has the cisco logo.
I did not install this callmanager but I have to maintenance it and I don't have idea how to solve this problem.
Thanks for your help.
Solved! Go to Solution.
05-12-2008 08:42 AM
Changing the Graphic on the Cisco Unified IP Phone Screen
javalenc
if this helps, please rate
05-12-2008 08:15 AM
most probably the devpack contained a new firmware, why don't you re-do the procedure for the 7912s background?
javalenc
05-12-2008 08:32 AM
Hi javalenc,
Please, can you tell me where I can find the info about re-do the procedure for the 7912s background?
Thanks a lot.
05-12-2008 08:42 AM
javalenc
