Change CCM in CUP
May 12th, 2008
Hi all
I have a CCM 6.0 and CUPS 6.0 . They are working properly. Now , CCM server is Failed. I must reinstall CCM Server with another IP address.
I don't know how to change IP Address of CCM in CUPS . Please help me.
agiaccone Mon, 05/12/2008 - 02:30
First, add the CUPS as an application server on your brand new CUCM.
Then, change the IP of the CUCM in your CUPS configuration in :
-CTI Gateway settings.
-Presence Gateways.
Restart the CUPS and everything should work if you keep the CUCM configuration unchanged.
Otherwise check the System->Troubleshooter tool on the CUPS.
If this helped please rate
Thucnk_FPT_FIS_6 Wed, 05/14/2008 - 07:36
Hi Alberto
I have changed CTI Gateway and presence gw already and restart CUPS . But In status menu , I still see CUPS to synchronize from old CUCM . I can't look up new user.
