pix porblem nat??? icmp???
May 12th, 2008
I have a problem a pix, from network 10.10.10.xxx attempt to ping to the Internet and not found, I attach the configuration if someone can see the error
gpepe Mon, 05/12/2008 - 06:16
I'm sorry, forget about commenting on statements that use but do not got nothing with it, which can be nat problem when I run my "sh xlate | grep" does not appear publishes ip
access-list EXTERNA permit icmp any any
icmp permit Externa
although write these lines not found
could be solved with these commands?
global (Externa) 6 xxx.xxx.xxx.25 netmask
nat (inside) 6 0 0
line1 --- access-list EXTERNA permit icmp any any
line2 --- access-list EXTERNA permit icmp any any echo-reply
static (inside,Externa) netmask 0 0
static (inside,Externa) xxx.xxx.xxx.25 netmask 0 0
access-group EXTERNA in interface Externa
route Externa xxx.xxx.xxx.24 xxx.xxx.xxxx.38
