Config doesn't appear after 30 mins on the Cisco Switch 3750
May 12th, 2008
Hi All,
When we add a line of configuration for some reason the configuration doesn't appear after a period of time (30 mins). It is almost like something is removing it but we can see any evidence of it.
Kindly let me know if someone have face this type ofissue earlier.
Thanks in advance.
Overall Rating: 4 (2 ratings)
Martin Parry Mon, 05/12/2008 - 04:32
  • Silver, 250 points or more
Can you confirm the command you are entering? If it is a command that is usually enabled by default then it will not appear within the config when you do a show run / show start
Martin
Sarasaqlain Mon, 05/12/2008 - 06:28
01(config)#line vty 0 4
01(config-line)#privilege level 15
waiting for your reply
noran01@icansp.com Mon, 05/12/2008 - 06:06
  • Bronze, 100 points or more
Is this switch part of a stack? If so, you should be making configuration changes on the stack master.
srue Mon, 05/12/2008 - 06:42
  • Blue, 1500 points or more
also try removing/disabling everything but console access temporarily. i've seen management tools that monitor configurations and devices make changes to configs.
disable telnet/ssh/snmp/http/https or any other access method besides console.
Sarasaqlain Mon, 05/12/2008 - 06:45
Hello Noran,
Yes this Switch is part of Stack and there are 6 switch on the stack and all of them are affected.
Now how do i go about this?????
Wating for your reply...
erinstadick Mon, 05/12/2008 - 09:54
We had this problem with that specific issue, turned out to be a bug in the version we upgraded to in the 3750, the privelege command just went away... I don't have the details on which bug it is but rest assured, you are not losing your mind:) (a bug search may find it)
erinstadick Mon, 05/12/2008 - 09:57
Found the bug for you......CSCsk18103, ironically, we had upgraded to this version of code to eliminate a different bug.....go figure..
Sarasaqlain Tue, 05/13/2008 - 02:26
Hi erin,
Thanks a ton for the reply. Heartly appriciated for the help.This solved my issue.
