Bandwidth Management
May 12th, 2008
I have been assigned to configure a new connection to an internet ISP. I am wondering if to configure bandwidth management, and how I can do this effectively on the Cisco 2821 edge router? I am also wondering whether third party bandwidth management solutions would be more appropriate?
Regards.
guruprasadr Mon, 05/12/2008 - 04:25
HI, [Pls Rate if HELPS]
Please use the QOS Method to do so. Refer www.cisco.com for more technical documents.
Best Regards,
Guru Prasad R
