gpulos Mon, 05/12/2008 - 08:29
  • Blue, 1500 points or more
Gatekeeper limitations/recommendations are as follows: (some limitations are mandated by hardware type & memory available)
max CCM Clusters Supported: 100
max Local Zones: not to exceed 100
max Remote Zones - Directory GK: not exceed 10,000 (if does not handle local registrations; requires 4MB additional)
max Zones (GK handles local registrations and e.164 calls): not to exceed 200
max Zones (GK handles h323-ID calls): not to exceed 200
mrugeshpatel_2 Mon, 05/12/2008 - 08:31
This information is useful, but my question still remains as to how many gateways can you register?
I am only doing one zone gatekeeper
gpulos Mon, 05/12/2008 - 08:36
no limit except for the limitations previously posted.
e.164s can have upto 10,000 for a DGK. i'd keep your local router/GK at 5,000 or below if it does all registrations and e.164 calls.
(should be a fast router; slower/smaller routers keep 2,000 or below)
dezoconnor Mon, 05/12/2008 - 10:47
  • Silver, 250 points or more
Hi Greg, if you don't mind me asking which reference doc did you find this info on?
Cheers. Darren
Michael Owuor Mon, 05/12/2008 - 11:34
  • Cisco Employee,
For gatekeeper performance data, we generally recommend that you solicit the help of your Cisco SE because the answer depends to a very large extent on what application the gatekeeper is supporting. That might also explain why there's little customer facing documentation on the subject.
A 3845 gatekeeper with 10 gateway endpoints registered to it and handling 5 calls per second would be under much less stress than one with 10 gateway endpoints registered to it and handling 50 calls per second.
Obviously the number of calls per second is an important factor when determining gatekeeper performance. Also important is the number of concurrent calls.
The guideline for a 3845 is a maximum capacity of 100 Calls per second, and 15000 active calls.
The CCM SRND states the following:
'The choice of gatekeeper platform is based on the number of calls per second and the number of concurrent calls. A higher number of calls per second requires a more powerful CPU, such as a Cisco 3700, 3800, or 7200 Series Router. A higher number of concurrent calls requires more memory. For the latest information on platform selection, contact your Cisco partner or Cisco Systems Engineer (SE).'
Hope this helps.
Michael.
MehmetKaya Fri, 10/07/2011 - 09:42
The the limitation  of gateways listed below;
Platform
Registered Endpoints
CPS
2801
Not recommended for   production GK applications
2811
5000
7500
20
2851
10000
30
3825
10000
60
3845
15000
70
AS5000XM
15000
100
2901
5000
7500
20
2921
10000
40
2951
10000
60
3925
15000
120
3945
15000
140
3925E
15000
200
3945E
15000
250
