BGP advertising route question
wilson_1234_2
Level 3
Level 3
I have an edge router that I will adveretise my ethernet subnet to Verizon via BGP.
My ethernet interface is:
10.10.10.254/16
My BGP config currently is:
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 6.1.2.9 remote-as 65000
no auto-summary
If I want to advertise my router etherent interface network to the third octet:
10.10.10.0/24
and not
10.10.0.0/16
Can I do this by adding the statement:
network 10.10.10.0 mask 255.255.255.0
I am asking because my understanding is that the network has to be in the route table in order for BGP to advertise the route and at the moment 10.10.10.0/24 is not in the route table.
It shows up as a connected route of 10.10.0.0/16.
Or will the "no auto summary" take care of that for me?
21 Replies 21
cisco_lad2004
Level 5
Level 5
usually it is the other way around. meaning the interface has longer mask, and we need to advertise a summary.
anyways, you can add a more specific route to Null0.
ip route 10.10.10.0 255.255.255.0 null0
and under BGP
pls help all helpful posts
Sam
Sam,
This will cause traffic to that /24 to be sent to null0 rather than on the Ethernet interface as it is more specific than the /16 configured on the Ethernet interface.
My question to the original poster would be why not configure the ethernet interface as a /24.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold,
I stand corrected, but would adding AD 200 to null static route avoid this ?
Sam
Sam,
No. The AD would only come into play for two routes with the same prefix length.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Harold,
Thanks for pointing this out, I missed one of the basic routing rules.
I am back to the drawing board.
Sam
guruprasadr
Level 7
Level 7
HI Wilson, [Pls Rate if HELPS]
The following example permits routes with prefix length up to 24 in network 10.10/16:
ip prefix-list abc permit 10.10.0.0/16 le 24
That was a mis-understanding of Question from my side, add a Route for the Network /24 pointing to NULL0 Interface and advertise with network statement. Because normally BGP will originate the Route for a prefix only if the Route for the same Prefix exists in the Global Routing Table.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
bvsnarayana03
Level 5
Level 5
Yes for BGP to advertise the network, the subnet of network should be in routing table.
As Sam told, this can be done by adding a static route the the subnet pointing to null interface. now you should be able to see the network in bgp table.
Wow, seven replys, you people must love BGP.
To answer the question about why a 16 bit mask.
We have servers that are using the SVI on the switch that this router is connected to and the SVI is 16 bit mask.
The servers are 10.10.50.0/16, the SVI is 10.10.10.254/16.
There is also a bridged connection to our DR side using this subnet.
Was it determined that I could not use the null route and if not then this will work?:
Wilson,
Configuring the /24 static route to null0 will definitely not work.
Why couldn't you just advertise the /16?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
It's cos you started a good thread !
no, Null0 not only wont work, but it woudl cause an outage. Apologies for misinfo.
The challenge here is to create a longer prefix ( /24) without affecting ur setup.
2 options:
1-why not advertise the whole /16 and block subnet you wish to secure.
2-"a shot from the hip"...are you able to split /16 and use secondary IP addresses under ethernet. so you create one line for teh /24 you need and few more using summarization to cover the remaining part of /16.
I hope there will be more input from other Netpros regarding option 2
Cause an outage huh, is that bad? It sounds kind of bad.
I could advertise the whole 16 bit mask, it just seemed to be better not to.
In reality, I will only be receiving SIP and RTP traffic from Verizon's SBC router, so I should be able to clamp it down pretty well.
I appreciate all the replys.
What about "redistribute connected", will this do the same thing as adding the "network" statement under BGP?
Wilson,
Another way would be to have the following configuration, which is kind of a hack.
interface Ethernet0/0
ip address 10.10.10.253 255.255.255.0 secondary
ip address 10.10.10.254 255.255.0.0
This way you could have a network statement for the /24 and it would be advertised as such.
I still prefer advertising the entire /16 though.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks hritter,
Wilson,
"redistribute connected" without any filter would redistribute all of the connected subnets on the box. I generally prefer to use the network statement in a case where you only have that one specific subnet to advertise.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
