WAAS - is possible to clear optimization statistics detail
Answered Question
May 12th, 2008
I need clear these statistics in the WEB GUI. Is possible to clear them? I tried to use clear cache dre, clear statistics all - but without success. Thank you.
Correct Answer by dstolt about 8 years 11 months ago
Roman,
Go into System, Configuration, System Properties. Change System.monitoring.recordLimitDays to 0 and then change it back to the # of days you have set in your system (I usually just leave set to default). That should clear your stats.
Hope that helps,
Dan
Overall Rating: 5 (2 ratings)
Correct Answer
dstolt Mon, 05/12/2008 - 06:32
  • Cisco Employee,
Roman,
Hope that helps,
Dan
