"csim start" command issue
May 12th, 2008
I am working with a 2811 ISR. The unit is using a single PRI to the PSTN. One small issue is that the customer has only a PVDM16 and therefore not enough DSP's to support the full PRI. I have told them to add another PVDM16. In the mean time I have configured the controller to use only 16 timeslots. When I test the ISR using the "csim start" command to any number I get the error below:
Voice-Lab#csim start 96472891369
csim: called number = 96472891369, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
Voice-Lab#
May 9 13:12:29.470: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x0 0x0, Called num 6472891369
May 9 13:12:29.470: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x008A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x80, '6472891369'
Plan:Unknown, Type:Unknown
May 9 13:12:29.474: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x008A
Cause i = 0x80AF - Resource unavailable, unspecified
May 9 13:12:29.562: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x808A
May 9 13:12:29.566: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x008A
I have attached my config. Any thoughts as to why this would be happening? TIA!
Brandon Buffin Mon, 05/12/2008 - 07:24
  • Purple, 4500 points or more
What does "show isdn status" indicate?
Brandon
flash2200 Mon, 05/12/2008 - 07:31
Up at Layer 2 and 3. (First thing I checked :)
shyamkumar.puppala Fri, 07/03/2015 - 10:03
XXXXXX#csim start 91XXXXXXXXX
csim: called number = 91XXXXXXX, loop count = 1 ping count = 0
csim: call attempted = 1, setup failed = 0, tone failed = 1
XXXXXXX#
Here tone failed=1.
What does it means whether issue at ISP or at local.
how can we confirm issue at ISP
Carlo Poggiarelli Fri, 07/03/2015 - 11:03
  • Green, 3000 points or more
Hi.
You have different debug option to use with  csim to determine where the issue belongs
In case of isdn debug isdn q931
in case of sip debug ccsip messages
in case of analogue line
debug vpm signal
Carlo
paolo bevilacqua Mon, 05/12/2008 - 08:27
  • Hall of Fame,
    Founding Member
They are not taking the call on channel 1, ask telco on which channel they start for your originated calls. You can configure timeslots 16-31 to try anyway.
flash2200 Mon, 05/12/2008 - 10:05
Thanks Paolo,
I will check this tomorrow when I am back at the client site.
