05-12-2008 07:11 AM
the customer configured time zone CET on all WAEs. In the CLI, the output from show clock is right. The show ntp status - is OK too. But when I used web GUI - time on some graphs is incorrect;-( Only when I used UTC time-zone for some graph outputs - time is correct (UTC time). When I used CM time or WAE local time - this time is incorrect. Can you help me? Thank you.
Solved! Go to Solution.
05-12-2008 08:10 AM
Roman,
Are you using a version newer then 4.0.15? If so, you might be encountering CSCsk16004. From the release notes for 4.0.15 - http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4015_v4017/release/notes/ws4015_4017rn.html#wp346391
Dan
05-12-2008 08:10 AM
Roman,
Dan
05-13-2008 07:30 AM
thank you very much.
