jrensink78 Mon, 05/12/2008 - 08:23
What are you looking to do with port security on your router ports?
Typically the point of port security is to prevent unauthorized devices from connecting to a specific access port. This really shouldn't be a concern on the connection that your routers use to talk to each other.
If you are looking to prevent a rogue router from messing up your HSRP groups, you can implement HSRP authentication.
