05-12-2008 09:02 AM - edited 03-15-2019 10:36 AM
I have a customer who wants to upgrade from CallManager 3.3(5) to 6.1.
As part of the upgrade we will be replacing the MCS servers as they are a few years old.
Obviously we cannot go directly from 3.3(5) to 6.1 so I am planning to install 3.3(5) on the new servers, copy the data from the old system using BARS and then upgrade to 4.2(3).
I will then use Data Migration Assistant to go from 4.2(3) to 6.1.
My question concerns Data Migration Assistant. Does it only generate Device License Units for devices that are actually registered to the 4.2(3) server as opposed to being defined in the database but not registered?
thanks
Solved! Go to Solution.
05-12-2008 04:10 PM
it will create the necessary DLUs for whatever you have currently configured on the server
javalenc
if this helps, please rate
05-12-2008 04:10 PM
javalenc
05-13-2008 06:23 AM
Thanks javalenc :-)
