X25 Troubleshooting
May 12th, 2008
Hi Everyone,
I'm trying to configure a 1841 Router to do a translate between one central running X.25 (EWSD) and a client running TCP/IP.
The PVCs between the central and the router are ok, but when i try to telnet the central i don't receive and response.
telnet 1.1.1.2 2001
I put my conf below...
If someone see some mistake in my conf or point me some link usefull to start a troubleshooting i will be apreciate that
Thanks in Advanced,
Andre Lomonaco
hostname rot_pra_x25_teste
x25 routing
interface Loopback0
ip address 1.1.1.1 255.255.255.252
interface FastEthernet0/0
ip address 10.121.243.12 255.255.248.0
duplex auto
speed auto
interface Serial0/0/1
description CENTRAL EWSD
no ip address
encapsulation x25 dce
x25 address 621141760006
x25 ltc 5
x25 ips 256
x25 ops 256
clockrate 2000000
lapb T2 300
lapb interface-outage 20000
lapb N1 8248
lapb N2 15
translate tcp 1.1.1.2 port 2001 x25 555140000237 pvc 1 packetsize 128 128 wind
size 2 2 max-users 1
translate tcp 1.1.1.2 port 2002 x25 555140000237 pvc 2 packetsize 128 128 wind
translate tcp 1.1.1.2 port 2003 x25 555140000237 pvc 3 packetsize 128 128 wind
translate tcp 1.1.1.2 port 2004 x25 555140000237 pvc 4 packetsize 128 128 wind
logging trap debugging
logging 10.33.52.46
logging 10.33.52.114
x25 route 555140000237 interface Serial0/0/1
line vty 0 4
password X
logging synchronous
login
line vty 5 15
password X
login
transport preferred telnet
Overall Rating: 4 (1 ratings)
paolo bevilacqua Mon, 05/12/2008 - 09:40
  • Hall of Fame,
    Founding Member
Whoops I had read badly. Please take debug x25 and debug translate when telnetting from a PC.
lomonaco Wed, 05/14/2008 - 04:24
Hi Bevilacqua,
I made a debug like you suggest and I got the following results
May 13 17:31:50.985: Serial0/0/1: X.25 O D1 Reset (5) 8 lci 1
*May 13 17:31:50.985: Cause 15, Diag 122 (Network operational (PVC)/Maintenance action)
*May 13 17:31:54.001: Serial0/0/1: X.25 O R/Inactive Restart (5) 8 lci 0
*May 13 17:31:54.001: Cause 7, Diag 0 (Network operational/No additional information)
*May 13 17:31:54.617: Serial0/0/1: X.25 I R3 Restart Confirm (3) 8 lci 0
*May 13 17:31:54.621: Serial0/0/1: X.25 O D1 Reset (5) 8 lci 1
*May 13 17:31:54.621: Cause 29, Diag 115 (Network out of order (PVC)/International link out of order)
*May 13 17:31:54.669: Serial0/0/1: X.25 I D3 Reset Confirm (3) 8 lci 1
*May 13 17:31:54.673: Serial0/0/1: X.25 I D1 Reset (5) 8 lci 2
*May 13 17:31:54.673: Cause 0, Diag 250 (DTE originated/Unknown diagnostic)
*May 13 17:31:54.673: Serial0/0/1: X.25 O D2 Reset Confirm (3) 8 lci 2
*May 13 17:31:54.677: Serial0/0/1: X.25 I P/Inactive Reset (5) 8 lci 3
*May 13 17:31:54.677: Cause 0, Diag 250 (DTE originated/Unknown diagnostic)
*May 13 17:31:54.677: %X25-7-DIAGEVENT: Interface Serial0/0/1, X.25 diagnostic event, Packet on unassigned logical channel, lci 3, packet discarded
*May 13 17:31:54.681: Serial0/0/1: X.25 O R1 Diagnostic (7) 8 lci 0
*May 13 17:31:54.681: error 36 (Packet on unassigned logical channel), 0x10 03 1B (Reset 8 lci 3)
*May 13 17:31:54.685: Serial0/0/1: X.25 I D1 Reset (5) 8 lci 4
*May 13 17:31:54.685: Cause 0, Diag 250 (DTE originated/Unknown diagnostic)
*May 13 17:31:54.685: Serial0/0/1: X.25 O D2 Reset Confirm (3) 8 lci 4
*May 13 17:31:54.869: Serial0/0/1: X.25 I D1 Reset (5) 8 lci 1
*May 13 17:31:54.869: Cause 0, Diag 250 (DTE originated/Unknown diagnostic)
*May 13 17:31:54.869: Serial0/0/1: X.25 O D2 Reset Confirm (3) 8 lci 1
Any tip or sugestion,
Thanks in Advanced and my best regards,
Andre Lomonaco
paolo bevilacqua Wed, 05/14/2008 - 06:04
  • Hall of Fame,
    Founding Member
Please configure SVC range (incoming/outgoing bidir) according to connected device.
lomonaco Thu, 05/15/2008 - 03:37
Hi Bevilacqua,
First, thanks a lot for your reply..
Can you explain in more detail what i should do ?
You can see in my configuration i have already define the PVCs range between 1 and 4
when i used the command x25 ltc 5.
I wanna use only this 4 PVCs, I don't wanna use SVCs..
First again and my best regards,
Andre Lomonaco
paolo bevilacqua Thu, 05/15/2008 - 14:34
  • Hall of Fame,
    Founding Member
Hi, it seems to me that trouble begins when router sends:
Can you try:
x25 lic 0
x25 ltc 0
x25 loc 0
to eliminate SVCs altogether. Take debug again. Post it here if different from before.
