SRST Translation Rule Inbound
hauchinango
Level 3
Level 3
I have a 2811 with PRI running SRST.
My telephone number range is 555-389-0800. I am recieving all 10 digits from telco, and am using 5 digit extensions. Since the first digit is a 9, I created a translations pattern in CCM so that extensions are 80800 rather than 90800. All works fine except I need to configure SRST.
Can anybody give me an example of a config translation rule for incoming that would ignore the first five digits and translate to 80800? Thanks
Try this one...
voice translation-rule 5
rule 1 /^555389\(....\)/ /8\1/
Use show voice translation-rule 5 xxxxxxxxxx
to verify.. x's are your 10d phone number
Should work a treat.
The /^555389 means match any number starting with 555389
the \(....\) means get the next 4 digits and treat them as a sub string
then the 2nd part is your replacement
8 to insert the 8
\1 to carry the substring from the matched pattern (your last 4 digits)
Cheers,
Tim
5 Replies 5
voice translation-rule 1
rule 1 /55538908../ /808../
voice translation-profile SRST-IN
translate called 1
voice-port x/x/x:23
translate called SRST-IN
Hope that helped.
Hmmm, I am getting a syntax error on this line
at the /8 mark
thanks
Router(cfg-translation-rule)#rule 1 /55538908../ /808../
OK...Im still somewhat new to translation rules, but if you have maybe 10 or 15 numbers at that site, you can do one to one translations, for example
rule 1 /5553890800/ /80800/
rule 2 /5553890801/ /80801/
rule 3 /5553890802/ /80802/
rule 4 /5553890803/ /80803/
and so on and so forth...then:
translate called 1
voice-port x/x/x:23
As I said before, if you have a large number of extensions at the site in question this may not work for you. But if you dont have that many extensions to translate you can give the above scenario a try.
Hope that helped.
Try this one...
8 to insert the 8
Cheers,
Tim
