stephan.steiner Tue, 05/13/2008 - 00:10
  • Silver, 250 points or more
As usual.. have you tried creating the element and tried to replicate the result you get from a get operation on the object? Are there any errors, and if so, which? If not, did you see anything funky in the AXL/DBL logs (I'm afraid up until release 5 the AXL logs don't contain DB information making the match a lot harder.. but it's still possible with a little effort).
And again.. you didn't mention the CCM version - which is crucial for AXL as the API changes quite often.
risiprekel Tue, 05/13/2008 - 04:12
Hi Stephan, I am working through this. Thanks. I am working with the call in all versions, so any example works.
I'll do a follow up to this post once I have it working, so anyone else that looks for this information will have an example.
