Is it possible to tell which CiscoIPPhoneMenu item a user selects?
May 12th, 2008
I am generating a CiscoIPPhoneMenu object using a list of strings. I do this so users do not have to remember a specific 'code' to enter in each time they use the application. The menu looks great, but I cannot determine how to tell which Menu Item the user selected.
I can make this work if I use the CiscoIPPhoneInput object instead, then the value the user enters is passed back to the web service. However, this forces the user to know the 'code' they are being asked to enter; which is what I'm trying to avoid. If anyone has any thoughts or ideas, I would greatly appreciate it.
Thank You For Your Time,
Michael
Sascha Monteiro Mon, 05/12/2008 - 19:45
  • Silver, 250 points or more
you can pass a unique menuID as a parameter to the url of the menuitem..??
developer_mike_smith Tue, 05/13/2008 - 04:21
Here's the fix I used:
QueryStringParam:message=" & x.ToString
where x.tostring is what is displayed on the menu item.
Thank You For Your Help
Michael
