1300 bridge question
Answered Question
May 12th, 2008
I have a set of bridges working right now on 1 vlan..which is the mgmt vlan I believe. What I need to do is add 4 more vlans plus a management vlan to this link for student registration(reg,quarentene,no -access and fullaccess vlans). The SSID I have now between the bridges is Wep'd..so do I need to individually add these's Vlans as well and wep them too? I'm kind of confused after reading the doc on the bridges they only use 1 vlan which isn't much help.
Also, both sides need to have the same Vlans configured right(local and remote)?
Thanks for any help,
Correct Answer by retiredmarine about 8 years 5 months ago
You extend VLANs into a wireless LAN by adding IEEE 802.11Q tag awareness to the access point/bridge. VLAN 802.1Q trunking is supported between root and non-root access point/bridges through the access point/bridges' primary SSID.
try this link:
Overall Rating: 4.5 (2 ratings)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
