WebVPN Content Rewrite?
May 12th, 2008
Hi All,
[ASA 5520, version 7.2]
Any help is appreciated. Users access Outlook WEB Access (OWA) via Cisco ASA WebVPN. Within the emails, if there are links to other sites, clicking on the links will not work. On the rewite rule in ASA, there is a default rule (#65535) and the resource mask is "*". I take it as rewite everything with the wild card "*". How do I:
(1) Allow all links to external resources be exempt, i.e. no rewite
Or
(2) Allow some external links to be exempt from rewriting.
What is the correct syntax on Resource Mask. Have searched everywhere but couldn't find anything on the format. An example will help tremendously.
Thank you.
fmeetz Fri, 05/16/2008 - 13:54
  • Bronze, 100 points or more
Use the following command
rewrite order 1 enable resource-mask *
command under the tunnel-group-list command
