2821 vs. 2851
rblankers
What is the practical difference between these routers? Is the processor difference really significant?
Edison Ortiz
The following link should be able to provide the information you are after:
http://www.cisco.com/en/US/products/ps5854/prod_models_comparison.html
It seems the 2851 supports NMD in addition to NME modules. The processor speed is also faster in the 2851.
2821 is rated at 87Mbps and 2851 is rated at 113Mbps
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
HTH,
__
Edison.
royalblues
Level 10
Level 10
The 2851 provides faster packet processing as compared to the 2821
It also supports the NME-XD type modules which the 2821 wont support
Have a look at the attachment
Narayan
thanks - the router performance document is the one I was looking for.
