Cisco Aironet 1240AG Series for Point-to-Multipoint-Bridging
Hi NetPro Forum,
is it possible to take the Cisco Aironet 1240AG Serie Access Points for Point-to-Multipoint installations??
For example one 1240AG AP in a central area with antenna AIR-ANT5160V-R and maybe two 1240AG AP's with antenna AIR-ANT5195P-R in our branch offices.....is it possible??
Thank you for your help
Stephan
Overall Rating: 4 (1 ratings)
SJessulat_2 Mon, 05/12/2008 - 23:38
Hi Stephan,
yes, this is possible. You can configure the central AP's 802.11a-Interface to root-bridge and the other APs' 802.11a-Interfaces to non-root-bridge.
The Ethernet-Port can be used for connectivity into the wired LAN, and the 802.11g-Interface can still be used for clients to access the wlan.
macse29474 Tue, 06/03/2008 - 12:52
Hi guys.
First, sorry for my english.
I configured a bridged network with 4 AP 1242AG.
The wireless network works but I have a problem:
any client connected on the 2,4 GHz cannot access to the VNC server.
The server and the clients are on the same lan but the server is connected to the AP (root bridge) ethernet interface.
The clients and the APs management are on different lan. only one ssid and only bridge-goup 1 f.or interface
You have an idea?
Thnks
SJessulat_2 Tue, 06/03/2008 - 21:54
what do you mean by "The clients and the APs management are on different lan"? Are they on different subnets/vlans?
Then you would have to explicitly configure the vlan of the clients to be transmitted over the bridge if it is not vlan 1.
Could you provide a topology plan of your network with vlans shown?
Greets, Sebastian
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
