enable_15 Account
May 12th, 2008
I have been doing some work tidying up the configs on my Pix fw's, i have noticed that when using PDM under User Accounts there is an account defined named
enable_15
However from the CLI this is not present in the config.
Does anyone know
1. What is this account for ? Is it some sort of default account
2. Can it be removed using the PDM without issue ?
Thanks in advance
Stuart
JORGE RODRIGUEZ Mon, 05/12/2008 - 19:05
  • Green, 3000 points or more
Hi, you will not be able to remove the enable_15 account as this is builtin enable mode account, you can remove any other account you have created with sec level from 0 to 14 but not the enable_15, it does not show in cli becuase it is not an account bound to any names.
-Jorge
