What box for this set of requirements?
May 12th, 2008
At least 16 ports 10/100/1000 VLAN switch
GRE tunnel interfaces that support multicast
1 or 2 RU
Cisco pulled support for tunnel interfaces in the workgroup switches, and ISR series routers NMs only go to 10/100. Do you need to go to a 6500 to get that combination of 2 features?
andrew.burns Fri, 05/16/2008 - 07:44
It depends whether you need hardware acceleration of the feature or not. If so, then yes, you'll need a 6500, but if not what about a 4948?
Andrew.
