Catalyst 2960 serial event log
May 12th, 2008
We have a catalyst 2960 IOS Version 12.2(25)FX and we want to know how can we displayed all events on a telnet session just like it does when you connect using a console cable?
We tried issuing a "show log" command but it didn't show all the information.
reybperez Mon, 05/12/2008 - 21:59
I'm not sure about the "terminal monitor" command. We are just wondering why when we issue the "show log" command under "telnet session" it doesn't give us the same information when we issue it under "console session". Is there any other command that we need to issue to get event logs of the this switch?
