SRST doesnt work with CCM4.3 AND IP PHONES 7945 &7941
May 12th, 2008
i have a CCM 4.3(1) working with 7945 and 7941 ip phones working, and a 2851 router with SRST, but when i see the ip phones supported by the SRST router, i only see other phones different. i have already configured the SRST but i does not work, does anyone know how to solve the problem?
giovanni.cock Thu, 05/15/2008 - 16:06
hi, thanks a lot for your answer, but i have alreday checked all these points. i send you more information about the TOip solution that i am working in.
do they all have the SRST reference?
a/yes they do.
do you have all the proper routing to reach the SRST?
a/the SRST router is the same voip gateway (pstn connections)
are they on the same vlan as working phones?
a/ the router is on the same vlan where the CCM is working in.
do you have the required SRST version and firmware loads?
these are the firmware:
COBOG-2851-VG1#sh call-manager-fallback
CONFIG (Version=4.1(0))
Version 4.1(0)
system message primary Sistema de Respaldo Activado
system message secondary Sistema de Respaldo
Limit number of DNs per phone:
7910: 36
7935: 36
7936: 36
7940: 36
7960: 36
7970: 36
Log (table parameters):
max-size: 150
retain-timer: 15
why i dont see the 7941 and 7945???
the router IOS is
and the ip phones firmware are:
7941 SCCP41.8-3-3SR2S
7945 SCCP45.8-3-3SR2S
these are higher that the document recomends, so i suposed that firmware version will work.
the CCM Version is, 4.3(2)
thanks a lot!
