"Object not found in device"
Answered Question
May 13th, 2008
When I try to add new Controller in the WCS (ver. 4.1.91.0) I get this error:
“Failed to add device to WCS Reason: Object not found in device”
The Controller has been added earlier a then deleted again. When I try to re-add the controller again, I get the above error. It's a WLC2106 I'm trying
Both the WCS and the new Controller works fine, and I have tried to boot them both.
Still get the same error when trying adding.
Anyone know what it could be?
TIA
Peter
Correct Answer by jeromehenry_2 about 8 years 11 months ago
Yes I would do that, or revert your controller to 4.1.185 if this version works well for you...
Overall Rating: 5 (1 ratings)
jeromehenry_2 Wed, 05/14/2008 - 10:14
  • Silver, 250 points or more
Which code is your controller running?
If your new controller code is not 4.1.X, this is a typical effect... WCS and controller should share the same major version...
hth
Jerome
PeterJacobsen Wed, 05/14/2008 - 21:54
Hi Jerome
The WLC2106 is running version 4.2.112.0.
I also have a WLC-4402 that is running 4.1.185.0.
Do you suggest that I upgrade the WLC-4402 to version 4.2.112.0. and the WCS to version 4.2.81.0.? Then all are running 4.2.x.x
TIA
Peter
Correct Answer
jeromehenry_2 Thu, 05/15/2008 - 02:46
PeterJacobsen Tue, 06/03/2008 - 04:05
af follow up...
After reinstalling to 4.1.185 I don't have the problem any more.
