TELNET AND RELOAD FROM LMS 3.0
Answered Question
May 13th, 2008
I am using Cisco LMS 3.0.From the devicee centre,how can i reboot a switch and when i click on the telnet link , it fails as well ?
Any idea how can i reboot a switch from LMS 3.0 and what configuration you need to do to telnet to it from the device cetre ?Is there any way you can clear the telnet session from the device centre ?
Correct Answer by Joe Clarke about 8 years 9 months ago
In order for telnet to work from Device Center, you need to have a telnet:// URL handler installed in your client's browser. On Windows, IE typically launches telnet.exe.
To reload a device, create a Reload Netconfig job under RME > Config Mgmt > Netconfig. Just select your device or devices, then select Reload from the task list.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 05/13/2008 - 05:07
