IOS DHCP server
May 13th, 2008
Is it possible to configure DHCP options 161, 164 and 165 in the IOS DHCP server?
I've downloaded a document explaining the configuration, but these options are not mentioned. Could be that it is not supported, but i would like confirmation on this.
Thnx!
paul.matthews Tue, 05/13/2008 - 00:46
  • Silver, 250 points or more
Some options are settable raw:
6506(dhcp-config)#opt
6506(dhcp-config)#option ?
<0-254> DHCP option code
6506(dhcp-config)#option 161 ?
ascii Data is an NVT ASCII string
hex Data is a hexadecimal string
instance Specify the option instance
ip Data is one or more IP addresses
