Route pattern
May 13th, 2008
Dear all,
I want to configure a route pattern to route call to the PSTN. To get the line on the PSTN network , i have to dial a security code number *54#1293*14#.
I configured my route pattern as :
- on the route pattern field : 1.[23789]XXXXXXX
- On the Discard digit field : Predot
- On the Prefix Digit (outgoing call): *54#1293*14#.
On my voice gateway , the dial-peer configured is :
dial-peer voice 70 pots
description LDHOTLINE
destination-pattern 1[23789].......
port 1/0/1
forward-digits 8
When i dial the number 1 96297967 from my IP phone , i have the message " Your call can not be computed" .
Thanks for your help.
gpulos Tue, 05/13/2008 - 03:31
  • Blue, 1500 points or more
You've got a routePattern that strips the "1" from the dialed digits before sending the call to the gateway.
Then you have a gateway with an outbound dial-peer that is requiring a "1" as the leading digit.
Remove the discard digit predot and the dot and test again. (or use another prefix number w/a dot and strip predot)
Bottom line is that your dial-peer will not accept numbers that dont start with "1" in this case.
(you could use the 'prefix' command under your dial-peer)
(plus 8 digits forwarded to the PSTN doesn't look right...if your USA, it is 7 digits or 11 digits (unless 1 prefix not required for some LD calls)
cameroun Wed, 05/14/2008 - 22:49
Hello gpulos.
I removed the discard digit predot and i configured the voice gateway as
destination-pattern *54#1293*14#1[23789].......
port 1/0/1
Now , the call is forwarded to the PSTN.
But the PSTN send a voice message telling that i must dial the code number first.
Which command can i use to be sure that all the digit *54#1293*14# are forwarded to the PSTN ?
Thanks.
