Unity MWI problem
May 13th, 2008
Hi Guys,
I have just one user affected by MWI.Firstly it was stuck on but i dialled the mwi of dn to turn it off.Now it wont illuminate even tho there is an unread voicemail.I would like to resynch the mwi`s but cannot seem to find where to do it or proper documentation. Unity version is 1.0....thanks.
Overall Rating: 5 (1 ratings)
rob.huffman Tue, 05/13/2008 - 05:07
Hi Bruce,
If this is Unity Connection 1.x
This was provided by Unity Design Master Jeff Lindborg;
Under web admin under Tools | Task Management.
Selet the "Resynchronize MWIs On All Phone Systems"
Hope this helps!
Rob
spotlight41 Fri, 05/23/2008 - 07:09
Rob,
Can you do this during production? I'm having this same issue on Unity Connection 1.2. Thanks.
rob.huffman Fri, 05/23/2008 - 07:31
Hi Steve,
Here is the info for Unity (which I'm sure carries across to UC as well);
"We recommend choosing a time outside of regular business hours because of the Cisco Unity resources needed for resynchronization."
If you are really having serious issues you can schedule it to Run>Now but I would try to do it outside of production hours if at all possible :)
Hope this helps!
Rob
