SSID not associated - wireless won't start
Answered Question
May 13th, 2008
What am I doing wrong? I have configured a blank 857w with the config described here:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
However I get an error when I no shut the Dot11Radio0 interface
config and sh outputs below.
thanks
Router#sh run
Building configuration...
*Mar 7 07:07:37.091: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1067 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 ssid Terrance2
vlan 1
authentication open
ip cef
archive
log config
hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid Terrance2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 15
power local ofdm 15
power client 17
station-role root
rts threshold 2312
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Router#
Router#
*Mar 7 07:06:51.699: %DOT11-4-NO_SSID: No SSID configured. Dot11Radio0 not started.
*Mar 7 07:06:51.703: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Router#sh ip int brief
Dot11Radio0 unassigned YES unset reset down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
ATM0 unassigned YES unset administratively down down
Vlan1 unassigned YES unset up up
Overall Rating: 5 (1 ratings)
simplecisco Tue, 05/13/2008 - 05:16
I have done a bit more and the Dot11Radio has come up but I still can't see it when I look for wireless networks?
Is the CLI the best way to configure wireless? Are there any troubleshooting commands I can use..
Router#sh run
Current configuration : 1484 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 ssid Terrance3
vlan 1
authentication open
wpa-psk ascii 0 cisco123
ip cef
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no ip address
ssid Terrance3
power local cck 15
power local ofdm 15
power client 17
station-role root
rts threshold 2312
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.0.1.1 255.255.255.0
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Router#
simplecisco Tue, 05/13/2008 - 06:32
I have resolved my issue with a much simpler config - listed below - still trying to work out what was missing with the above.
sh rn
% Invalid input detected at '^' marker.
Router#sh run
Current configuration : 1736 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 ssid TERRANCE2
authentication open
--More-- authentication key-management wpa
guest-mode
wpa-psk ascii 0 0102030405
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.254
ip dhcp pool dhcppool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
update arp
ip cef
ip domain name local
archive
log config
--More-- hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no ip address
--More-- !
encryption mode ciphers tkip
ssid TERRANCE2
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
no cdp enable
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.1.254 255.255.255.0
--More-- ip access-group 102 in
ip nat inside
ip virtual-reassembly
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
end
Router#
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
