CUCM 6.1 Intercom
Answered Question
May 13th, 2008
Is there a way to go into auto-answer and unmute on intercom? You can do this on CME, but I can't find a way to do this in 6.1.
Correct Answer by Rob Huffman about 8 years 9 months ago
Hi Mike,
You can if you use the "old" method I mentioned. It will work exactly as you described :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 05/13/2008 - 05:41
Hi Mike,
Sadly, no. It is because of the ability to work regardless if the Far-End phone is Busy or not. Here is a clip;
The Intercom feature allows a user to place a call to a predefined target (phone). The called destination auto-answers the call in speakerphone mode with mute activated. This sets up a one-way voice path between the initiator and the destination, so the initiator can deliver a short message, regardless of whether the called party is **busy or idle.
To ensure that the voice of the called party is not sent back to the caller when the intercom call is automatically answered, Cisco Unified Communications Manager implements whisper intercom. Whisper intercom provides only one-way audio from the caller to the called party. **The called party must manually press a key to talk to the caller.
From this 6.x doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/release/notes/cucmbe_relnotes/601ccmrn.html#wp218023
You could always use the "old" method of setting up a Speeddial Button on the caller phone to a DN that Auto Answers on the Far-End (no mute :)
Hope this helps!
Rob
mikepinto Tue, 05/13/2008 - 07:06
Thanks Rob. Cisco really needs to get its act together to match features across different appliances. If I can do it on one (CME) I should be able to do it on another (CUCM). Especially when the one you can't do it on is the more expensive solution. So from your post, I'm guessing I can't make the Intercom busy if the person is on the phone, or is that configurable?
Correct Answer
Rob Huffman Tue, 05/13/2008 - 07:13
Hi Mike,
Hope this helps!
Rob
mikepinto Tue, 05/13/2008 - 08:12
Thanks. One last question. Where can I get the intercom tone?
