DSP calculation question
May 13th, 2008
I have one PVDM2-32 (2 DSPs c5510 on the plane) on the board of 2821 ISR.
Under voice card I prefer to use high complexity, i.e. 6 channel per DSP (12 channels in total).
While I'm configuring PRI using 10 TS, router claims:
(config-controller)#pri-group timeslots 1-10
% Not enough DSP resources available to configure pri-group on controller E1 0/1/0
% The remaining dsp resources are enough for 8 time slots.
% For current codec complexity, 1 extra dsp(s) are required to create this voice port.
What is the reason ? Attaching 'sh voice dsp det' below.
#sh voice dsp detailed
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 02 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 03 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 04 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 05 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 06 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 01 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 02 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 03 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 04 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 05 None 8.4.0 idle idle 0 0 0 0/0
C5510 002 06 None 8.4.0 idle idle 0 0 0 0/0
*DSP SIGNALING CHANNELS*
C5510 002 01 {high} 8.4.0 alloc idle 0 0 0/2/0 02 0 15/0
C5510 002 02 {high} 8.4.0 alloc idle 0 0 0/2/1 02 0 15/0
C5510 002 03 {high} 8.4.0 alloc idle 0 0 0/3/0 02 0 36/0
C5510 002 04 {high} 8.4.0 alloc idle 0 0 0/3/1 06 0 36/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Overall Rating: 2 (1 ratings)
Tobivan_Helden_2 Tue, 05/13/2008 - 06:20
I've got an idea: am I right if suggest, that 4 channels are occupied by fxs/fxo assignements ?
Tobivan_Helden_2 Tue, 05/13/2008 - 06:22
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/2/0 -- fxs-ls up dorm on-hook idle y
0/2/1 -- fxs-ls up dorm on-hook idle y
0/3/0 -- fxo-ls up dorm idle on-hook y
0/3/1 -- fxo-ls up dorm idle on-hook y
gpulos Tue, 05/13/2008 - 06:31
  • Blue, 1500 points or more
The router is showing you correctly.
You have enough DSP resources for only 8 channels.
You must have enough DSPs to support 10 channels. This would require 3 DSPs in your case for 10 g711 channels.
(4 channels per DSP in g711 for c5510 type DSPs)
(g711 because the telco is sending you g711 voice calls)
Please see the following link for the DSP Calulator to help identify what your hardware can support and how many DSPs you need to meet your requirements:
http://www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
(requires cco login which is free to register for)
