Problem with PPTP server on Cisco 851
May 13th, 2008
Hi, All!
Sorry for my bad english =)
I have a small network 10.15.0.0 /24
Cisco is a gateway and DHCP server for internal network.
ISP link is directly connected to fa4
I've been requested to configure PPTP server on this device for remote users
Config is below:
sh ver:
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(4)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:29 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
config:
aaa new-model
aaa authentication login default local
aaa authentication ppp vpn local
aaa authorization console
aaa authorization exec default local
aaa authorization network vpn local
ip subnet-zero
ip dhcp excluded-address 10.15.0.1
ip dhcp excluded-address 10.15.0.2
ip dhcp pool DHCPPOOL
import all
network 10.15.0.0 255.255.255.0
default-router 10.15.0.1
dns-server 10.15.0.2 10.15.0.1 195.112.*.*
domain-name wr
lease 2
ip cef
ip domain name NAMETHERE
ip name-server 195.112.*.*
vpdn enable
username vpn password 0 test
username vpn aaa attribute list vpn
interface FastEthernet4
description WAN interface
ip address 195.112.*.* 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Vlan1
peer default ip address dhcp-pool DHCPPOOL
ppp authentication ms-chap
interface Vlan1
ip address 10.15.0.1 255.255.255.0
ip broadcast-address 10.15.0.255
ip nat inside
ip default-gateway *.*.*.*
ip classless
ip route 0.0.0.0 0.0.0.0 *.*.*.*
Remote user's can connect to this network, but they obtain wrong tcp\ip parameters.
example:
testpptp - PPP:
DNS-suffix . . :
description . . . . . . . . . . . . : WAN (PPP/SLIP) Interface
physical address. . . . . . . . . : 00-53-45-00-00-00
Dhcp enable. . . . . . . . . . . : no
IP-address . . . . . . . . . . . . : 10.15.0.19
Subnet Mask . . . . . . . . . . : 255.255.255.255
GateWay . . . . . . . . . . :
DNS-servers . . . . . . . . . . . : 195.112.*.* 195.112.*.*
So they obtain correct ip address, but incorrect DNS server, gateway, subnet mask.
And question is WHY? :)
I hope i wrote it correctly and clearly.
bwilmoth Mon, 05/19/2008 - 10:19
Can you see the translation for GRE. Could you provide the details of sh ver, sh access-list and show log
