More than 2 ISP links on cisco router with Folt tolenrance and load Balance
Answered Question
May 13th, 2008
Dear all,
i checked the forum for the notes about connecting two ISP lines to a single router by using "IOS NAT Load-Balancing". Can this feature be used for more than two lines ??
Thanks and kind regards
Matthias
Correct Answer by Paolo Bevilacqua about 8 years 9 months ago
Yes.
Overall Rating: 5 (1 ratings)
Richard Burts Tue, 05/13/2008 - 07:23
Matthias
I am not clear exactly which implementation you are looking at. But I am confident that with appropriate modification it could be used for more than 2 lines. If you could provide details of what you are thinking about doing or the links that you found we may be able to give better answers.
Rick
schuetzm Thu, 05/15/2008 - 08:37
Rick,
the distance between our customer's site and the providers dslam-box is to big to get a higher bandwidth than 1 mbps. More significant solutions are to expensive.
So we need to find a moderately priced solution. My challenge is to find a solution for bundling 2,3 or 4 dsl-lines (each with 1 mpbs).
Does IOS-NAT-Load-Balancing support more than 2 links ??
Kind regards
Matthias
