05-13-2008 07:02 AM
While configuring the source router, the ip sla monitor command requires additional commands.
Where can i can find the exact command
Solved! Go to Solution.
05-13-2008 08:59 AM
Yes, SNMPv3 is supported. It would help to see the configuration and show ver from this device.
05-13-2008 07:11 AM
What exactly do you want to do? If you're using IPM, then IPM will do all of the setup for you. All you need is SNMP read-write credentials on the device. The only thing you may want to configure is the IP SLA responder. That command is simply:
ip sla monitor responder
05-13-2008 07:32 AM
I am using snmp v3 read and write view on the router and the IP SLA does not see the router as possible source.
Does it support v3 or just v2
05-13-2008 08:59 AM
