05-13-2008 08:12 AM
I want to use only full optimalization for HTTP (TFO, DRE and LZ). Is possible to use an "one-click" method for configuration all default policy (without http) to pass-through in WEB GUI? I only tried to change some policies to pass-through (open policy - change it to pass-through, save policy), but it is time consuming method:-( There are cca. 150 policies:-( Thank you.
Solved! Go to Solution.
05-13-2008 09:04 AM
Roman,
Change you HTTP policy to be the first priority in your list. Then create a new application policy, when you define the match list, set it to Match All. Then set that policy into Pass Through. Then put that policy into the 2nd position behind the HTTP policy in your Priortization list.
WARNING> You will only get stats on HTTP and Other (or whatever application you put your new policy in). All traffic outside of HTTP will be in the "other" reporting bucket.
Dan
05-13-2008 09:04 AM
Roman,
Dan
05-14-2008 06:13 AM
It helps me. Thank you.
