CUCM 6.1 ROLM 9751 Integration
I've been tasked with a CUCM/ROLM integration. I need to do extension to extension dialing between the two systems and possibly use the ROLM as the PSTN gateway for the CUCM. I have done an NEC CUCM integration for ext2ext but never touched a ROLM. Does anyone now where to start with a project like this? Does the ROLM 9751 support a T1 QSIG integration? Has anyone ever performed an integration like this?
Thank you
kdamisch Wed, 08/13/2008 - 09:04
We are doing one, but having problems with caller ID and also with trunk to trunk transfers. What issues did you run into?
Tommer Catlin Wed, 08/13/2008 - 11:35
No qsig on that version of the Rolm. It's only a straight T1 CAS. No caller ID.. which stinks. I dont think they have a qsig package if they do, its probably really expensive!
