UC500 vs 1861
Answered Question
May 13th, 2008
Can someone help me out with this. What is the difference between a UC500 and a 1861 ? Is the 1861 considered to be a traditional ISR ? or a product in the SBCS ? From product description it describes the 1861 being able to SRST but UC500 does not.. are there other differences?
I think Cisco is making this confusing ;)
Correct Answer by Paolo Bevilacqua about 8 years 5 months ago
In short, the 1861 is a full-featured router, the UC500 is not. Check:
And a good eye to prices too.
Overall Rating: 5 (1 ratings)
a.gooding Tue, 05/13/2008 - 20:40
just to add something as well in summary
1861 - 8 users, comes either SRST or CME- marketed as a router and is able to integrate (SRST or CME/SRST) with CCM
UC500- 8-48 Users according to bundle. Not marketed as a router.Not able to directly integrate to CCM as opposed to the above.
Paolo Bevilacqua Wed, 05/14/2008 - 02:44
UC500 - True, you cannot integrate as SRST. All other types of integrations to CM are OK and supported.
