1250 w/AIR-ANT2430V-R Which cable is antenna A - B - C or does it matter
Answered Question
May 13th, 2008
Please help I have read every doc on this AP and this antenna. there are three jacks on the radio labeled a - b and c. There are three cables on the antenna. which cable corresponds to the correct radio antenna label. Or does it not matter. Looking at the radiation patterns on the antenna I tend to think that it makes a difference. Thanks the info.
Jason
Correct Answer by dennischolmes about 8 years 11 months ago
The main thing to consider would be that the center cable should be connected to the center jack. The others should not matter as they are the outbound antennae and in mimo the center antenna is the critical unit for phase differentiation. The phase shift mechanisim in the unit will take into effect the other 2 antennae and their position.
Overall Rating: 5 (1 ratings)
Correct Answer
dennischolmes Tue, 05/13/2008 - 15:08
  • Gold, 750 points or more
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
