IOS compatbility with Hardware ( ADSL/BGP)
May 13th, 2008
I need help, will appreciate it greatly if someone can assist.
Following is the output from my Router. I need to have an IOS which recognizes my ADSL WIC card plus i can configure BGP also. Problem is i can't seem to locate the IOS with my Memory/HARDWARE which can support ADSL plus BGP. Any help will be appreciated.
Commerce-Valley-CE#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:24 by dchih
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Commerce-Valley-CE uptime is 8 minutes
System image file is "flash:c2600-ipbase-mz.123-26.bin"
cisco 2620XM (MPC860P) processor (revision 0x100) with 49152K/16384K bytes of memory.
Processor board ID JAD071305V5 (1789417009)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ATM network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Commerce-Valley-CE# sh diag
Slot 0:
C2621XM 1FE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
PCB Serial Number : JAD071305V5 (1789417009)
Part Number : 73-7753-02
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : B0
Deviation Number : 0-0
Product (FRU) Number : C2620XM-1FE
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6C 41 01 00 C1 18 4A 41 44 30 37 31
WIC Slot 0:
FT1 BT8360
Hardware revision 1.3 Board revision C0
Serial number 27467070 Part number 800-03279-04
FRU Part Number WIC-1DSU-T1=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 A3 1D 3E 50 0C CF 04 00 00 00 00
0x30: 60 00 00 00 01 12 15 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
DSL SAR (ADSL)
Hardware Revision : 2.3
Part Number : 73-4771-09
Board Revision : C0
Fab Version : 05
PCB Serial Number : FOC08121WNG
RMA Test History : 00
RMA History : 00
Product (FRU) Number : PA-1C-P=
0x00: 04 FF 40 00 2E 41 02 03 82 49 12 A3 09 42 43 30
paolo bevilacqua Tue, 05/13/2008 - 12:06
  • Hall of Fame,
    Founding Member
Any 12.4 IOS will do that, the issue is that you need customer-level access (support contract) to download, and expanded flash and ram to use it.
