LMS3 - SNMP V3
Answered Question
May 13th, 2008
I have configured Cisco Catalyst 2950 L2 switches with the view oid-tree included, however, it appears that the LMS cannot read the chassis and identify as a switch and all the switch reports are invalid.
If there is another MIB view that I can use.
Correct Answer by Joe Clarke about 8 years 9 months ago
As I said in the other thread, SNMPv3 and 2950s don't mix. For full management capability, you need to stick with v1/v2c on these devices. Any device which can run 12.2 or higher code can make full use of SNMPv3.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 05/13/2008 - 11:56
ashley_dew Wed, 05/14/2008 - 10:01
Problem solved, thank you very much.
Just to add i have got a 2960 with 12.2(22) IOS i got all details but user tracking still fails with SNMP V3, but with V1/2 its fine.
Problem solved, fantastic job
Thx,
Ashley
Joe Clarke Wed, 05/14/2008 - 11:19
12.2(22) is not a valid IOS version for the 2960s. However, even with context-supporting code, you need to allow LMS to poll each context. First, run "show snmp context". Then, for each context, configure your SNMPv3 group to allow polling:
snmp-server group GROUP v3 auth context CONTEXT
For example:
snmp-server group v3group v3 auth context vlan-100
