05-13-2008 11:57 AM - edited 03-05-2019 10:56 PM
I need to stop telnet traffic and use SSH to my 2960s.
I see a global IP SSH version command
other then that it should be setting an IP Domiain Name, Crypto Key generate and setting the input on the VTY.
Am I forgetting anything?
Andy
Solved! Go to Solution.
05-13-2008 12:00 PM
Andy
Sounds about right except that you need to either
1) Create a username/password on the switch for ssh access
or
2) use an ACS server to authenticate the user.
You cannot use the line password for ssh.
Have a look at this link for further reference.
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Jon
05-13-2008 12:00 PM
Andy
or
Jon
05-13-2008 12:00 PM
That should pretty much cover everything you need to do.
HTH,
__
Edison.
