CER Hardware
May 13th, 2008
I got a customer with CER 1.3.2 running on a MCS7835-H2-CC1E. They're upgrading to CER 2.0.3. Based on the release notes for both 1.3 and 2.0 CER, it doesn't show CC1E as one of the compatible hardwares to go with but 1.3.2 is running just fine on it - it has for the past 6 months. Does anyone know if CER 2.0.3 will run fine on a 7835-H2-CC1E server? We are installing from scratch and using DMA to import database back.
SAN J Wed, 05/14/2008 - 08:11
The server is actually MCS7835-H2-CCE1 (not CC1E). Anyway, it's still not on the list. I don't have the S/N handy but I did look at the top of the server to verify the type of server when I was there. Does it really matter what the type is? Do the software/DVDs look specifically for these or just that it is a MCS 7835 H2 class server?
